Starting& staying running problem :(
StillDyl
Oregon
it starts right up when you jump it. but when i try to start it with out a jump nothing at all turns on, not any electronics no clicks no nothing.
when i get it running with a jump it will drive fine sometimes. but other times the second i let off the gas its dead.
it seems to idle just at 1k or a tad below at times. is that ok?
i cleaned up the battery terminals, checked the connections and it seems to be fine.
any ideas...
Vnuk1
Mr. Mayhem
Minnesota
Sounds like your Battery is toast.:slap:
StillDyl
Oregon
i dont think its the battery because it starts up fine and runs perfectly when it wants to. just randomly it wont.
Vnuk1
Mr. Mayhem
Minnesota
But in your OP you say you always have to jump it. I guess it could be alot of things, loose connection, bad ground, Ignition switch etc. Idle seems ok.
StillDyl
Oregon
all the connections seem to be solid.
and the check engine light isnt on
jpSHO
Massachusetts
Everytime you disconnect the battery or it dies the computer has to relearn itself which is causing your high idle. As for the car not starting sometimes I would check the wires at the starter make sure they are tight and clean them.
StillDyl
Oregon
ya there were some.
ill have to get back to you on what it is because the computer i have access to is at a friends house.
hawkeye18
Sorta cares
Norfolk, VA
I also vote bad battery. Which is probably caused by a bad alternator. One being bad will very quickly make the other bad too.
hawkeye18
Sorta cares
Norfolk, VA
yeah... dude, own a SHO long enough and you learn to keep a friggin' stockpile of batteries and alts. Between my two cars, I have two alts and three batteries - and those are the ones that aren't in a car. The number goes up to 4 and 6 if you count those!
hawkeye18
Sorta cares
Norfolk, VA
then it might be a loose connection. Check the battery, the starter (both the hot side and the big ground lug) and the b+ cable at the alternator.
StillDyl
Oregon
i know this is a realllllly old topic but i replaced the starter and were all good!
the little bastard was hard to take out but it was easier to put in,and napa gave me one with a lifetime warranty
