Starting Issue
screaminsho
Scituate, MA
This has been an issue for a while. My car has intermittant starting problems, excessive carnking (sometimes), turn key back, forward, fires right up, starts without problem the first start of the day. I searched the forums and few matches but never a resolution. come on someone must know how to solve this.
Emerald94
Mississauga, Ontario, Canada
It sounds like the fuel return line check valve.
It's not keeping fuel in after you shut off your car hence the long cranking time (The pump has to repressurize the system). Just turn the key but don't start the engine just yet. Let the pump spin a bit then start the car.
A new fuel pump will take care of the problem. Is yours noisy?
rob 4 sho
new orleans
my sho gives me the same problem it starts fine the first crank of the day but every time after that it doesn't want to start.
brandon
Ohio
Hmm i had the same problem i had a quit fuel pump an all put check the presure an it was very low i put a new on in an it started fine
Try flooring the gas pedal and cranking when it doesn't want to start.
markmoomnu
