Stalling...
D
dkautumna
Guest
My 90 sho just started doing it. If I slow down and engage the clutch... it stalls. If I start it and engage the clutch... it stalls. I have to immediately put it in 1st. The only thing I have done is disconnected the battery to install a new stereo/cass. Could that have anything to do with it?
I would be willing to guess (OR HOPE!) that this belongs in the open forum, under "Why do SHOs fix themselves", in a day or so it will probably be fine.
It happened once before when I had my radiator fixed... it lasted a half a day, then it was fine.
David
You just need to reset te idle programming. See my last response to the Rough Idle post in this topic.
http://www.shoforum.com/ubb/Forum17/HTML/000945.html
Scott
1991, 255K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/poly, Alum front SFB, SS front/rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
D
dkautumna
Guest
I tried resetting it, but appearantly it did not work or I did not do it right. For 2 days straight, taking my car out was "fun" to say the least. It would stall every time I downshifted to make a turn and every time I came to a stop, but it would run fine other than that. I drove her hard today to sho her who the boss is... and she submitted to my authority! Strangely, she is all better- idle is back to normal (her normal).
