Spring Clamps. Lowering????
wdnitro
Houston,TX
Has anyone ever tried these. They clamp onto your springs in two places, thus lowering the spring by about an inch. Is this the poor stupid man's way of lowering, or does it work okay??
texas hot rodder
dfw texas
I would expect Sh*tty ride, and if they actually whithstood enough stress to hold the car down an inch, I would not want to be near when one breaks and pieces go flying. Should be a harse ride. Save for new springs,struts.
God Luck, Craig
wdnitro
Houston,TX
From what I've seen they are forged steel. Two plates for top and bottom and then attached both plates with two bolts. This would be done on both sides of the spring condensing one coil length.
texas hot rodder
dfw texas
It may be really strong, and it might work, but I would not do it to my own, I am saving for Intrax, cut off the extra coil, and use koni's for adjustability. $$ but worth it. If I were broke I would buy some nice used springs from someone like me and cut a coil. Craig
Ishodu
Usually when you take the cheap way. You will get cheap results. Do it right the first time and save the money and buy the right stuff the first time instead of getting cheap stuff then getting the good stuff later on..
fast-r-sho
valdosta,GA
dont use the clamps and DONT CUT THE SPRINGS!!!!
I know anout cutting the springs from personal experience on a sho....i didnt help my other problems any,looked good,rode like ass...just buy intraxx or tokicos
wdnitro
Houston,TX
That's want I wanted to hear. NO positive responces yet.Thanks for the input.
Spring Clamps bs
