Speed limit
SHO5
ADDICTED
Fond du Lac, WI
The superchip does help if you get the right one. It improves shifts (faster) noticably and the performance is a little better but not as noticable.
ncmcn
Cumberland, RI, USA
SHOZRJUSTBETTER:
Does superchip teach english? How help yours?
Bwuuuaaaahaaaaa!!! :D :D
SuperChip!
Warning: Pregnant women, the elderly and children under 10 should avoid prolonged exposure to SuperChip.
Caution: SuperChip may suddenly accelerate to dangerous speeds.
SuperChip Contains a liquid core, which, if exposed due to rupture, should not be touched, inhaled, or looked at.
Do not use SuperChip on concrete.
Discontinue use of SuperChip if any of the following occurs:
Itching
Vertigo
Dizziness
Tingling in extremities
Loss of balance or coordination
Slurred speech
Temporary blindness
Profuse sweating
Heart palpitations
If SuperChip begins to smoke, get away immediately. Seek shelter and cover head.
SuperChip may stick to certain types of skin.
When not in use, SuperChip should be returned to its special container and kept under refrigeration...
Failure to do so relieves the makers of SuperChip, Wacky Products Incorporated, and its parent company Global Chemical Unlimited, of any and all liability.
Ingredients of SuperChip include an unknown glowing substance which fell to Earth, presumably from outer space.
SuperChip has been shipped to our troops in Saudi Arabia and is also being dropped by our warplanes on Iraq.
Do not taunt SuperChip.
SuperChip comes with a lifetime guarantee.
SuperChip
ACCEPT NO SUBSTITUTES!
SHODWN
Mother Threasa
Spencer,Ma usa
The Superchip with the LBL1 Code will do 2 things..
1. Noticeably (sp) Improve the Shifting and firmness.
2. Cost you about 5hp and 9ft TQ
on a side note if you send it back because of the losses you will lose 5 times as much. Been there done that..
MarkieSHO
Manchester
So is it worth getting a Superchip or are there any performance chips out tehre that are better?
SCOTTDW
Memphis, TN, USA
I just do not know where a Superchip has enhanced performance on these cars. Nearly 4 years of monitoring the V8 SHO community....chips suck in general on these cars. Can anyone really document some good stuff? Guess what I mean is what chip gives you a better 0 to 60? Which chip gives you better 60 to 140? Does that chip exist? Will put it on my next GENIII.
Scott
98SF
Magnaflows
(stolen)
<small>[ April 26, 2003, 11:07 PM: Message edited by: SCOTTDW ]</small>
The FordChip I have definitely improved things. Much better shifting and at least a .2 in the quarter. Plus got rid of the EGR and SAI error code triggers.
The Apten chip sounds like it is as good or better with a higher level of customer service.
The FordChip and Apten chip are programed by people who are very familiar with Ford's OBD II and PCM coding. Something Diablo and Superchip apparently are not.
ohioshodude
SHO'ld fogy
delaware, ohio
hey paul, can they write out sensors, or ignore them? things like the EGR, and crap like that? it's would be cool to get rid of all the extra stuff on the engine.
<small>[ April 27, 2003, 03:30 AM: Message edited by: ohioshodude ]</small>
Depends on the sensor. I have the EGR valve removed on my '97. I still have all the rest of the system on it. Next time the intake comes off it will be removed as well.
I also have the SAI system codes written out. If I ever have the opportunity to remove this plumbing it will go too.
