2010 sho under hard acceleration it hits rev limiter but doesn't accelerate
raising cain
Oregon
I have a 2010 sho that's all stock with close to 183k. It does have a engine light on with codes p0113, p0114, p0138, p0158, p0453 , p1000.
I have replaced the IAT sensor in the air box and still have that code.
Alright other than the engine light on. My other problem is if I go WOT it will bounce off the rev limiter and not accelerate. It feels like a clutch is slipping in a manual transmission car. It doesn't matter on the speed either. I also have replaced the spark plugs.
Any help and direction with any of these issues would be great or should I just sell it ?
Joshw0000
North Carolina
Well that's a bummer. Thanks for the response
Double check that the transmission fluid is good and to the proper fill. If so, add a couple tubes of Shudder Fixx to it. It'll get better almost instantly. If the issue comes back you need a new torque converter. Happened to me too.
Sent from my Pixel 8 Pro using Tapatalk
WarrenBoostit
Minnesota
Agree with others, just went through a similar fiasco in my 2018. The TCs in these cars leave a lot to be desired even at stock power. Hoping shudderfix can get you some more miles, I went straight to transmission rebuild, as this tends to result in that, and unfortunately $7.3k later the problem was resolved.
shootinirons
