Tweecer rev limit
shaldaya
Utah
I finally got me a tweecer, but it says the rpm limit is based off clock speed, can anyone help?
I'm trying to set my rev limit to 8,500
Any additional information on the tweecer would also be highly appreciated
Joe_SHO
ND
Check out eectuning.org and efidynotuning.com. Lots of information and helpful folks there.
Joe_SHO
ND
What software are you using? I have mostly used binary editor, but I have played around with tunerpro a little. I suspect there's a scalar under the fuel category where you simply change fuel cutoff rpm or something like that. My tuning experience is on a 1993 f250 with a 460, so max rpm hasn't been a concern.
Make small changes at a time. Good luck and have fun with it!
shaldaya
Utah
I was using cal edit
Is there other software i can use with the tweecer?
shootinirons
