Spare Manual Transmission?
chrism3784
West Palm Beach, Florida
I don't have front upgrade. So bias plugs would be fine right?
Darn 38sho, I have a spare hard button eatc. Also theres like 1 or 2 in the junkyards somewhere. I'm going to have A/C to, mine leaked somewhere, so I'm changing out all o-rings which hopefully stops the leak.
38SHO
#1 Oil Abuser
North Palm Beach
crap, well I already bought one from Dan Barbush, hes a reputable dude
I've been looking and all the ones I've seen were the pre 95 versions/broken
chrism3784
I just saw something about welding the diff pins to make that problem from ever happening what I just went through. I know a welding shop. How easy is it to take the diff off. I still have the tranny out?
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
A good welder can guarentee his welds. Diff welding is not too hard, get some new hardened rollers and bring them to a reputable welder. 3/8" steel rods to weld it all together.
chrism3784
I can't afford the quaise. I'm probably just going to stick it in like that till I see a junkyard tranny that isn't screwed over, I'll take the diff out of it right at the junkyard and get those welded and pull the engine/tranny and do it again. Till then I'll drive it nice, no burnouts.
chrism3784
Me and 38sho put the engine and tranny back in on the mounts. as im putting everything back in, noticed one problem. the clutch tob fork arm thingy seems pretty tight. i put new ceramic bushings in and had to hammer the fork back in. connected the cluth and it swings in pretty easily when pushing down the clutch. let go of the clutch and arm doesnt go back easily. i can push it back pretty easily, but wont be able to do that while driving. You think it will just wear itself in, or is this common on the new bushings. im going to keep pushing it back and forth for a while before i officially finish it and drive it.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
I know the transmission worked fine when pulled. Did you replace those bushings Jason was telling you to swap over for the cable fork?
chrism3784
Sure did, and the new ones I think are very tight. That lever was really hard to get back in. had to hammer it. I just hope it wears itself in to make the car drivable. Right now if I was to drive it, I would push clutch in and it would stay in. Maybe I can hook some kind of spring onto it to pull it back. Keep it there till it wears itself in, if it ever.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
With the **** in there you should be able to smooth it out after moving it back and forth x amount of times as Kelvin said. Hopefully you can make the meet with it.
313tiger
