That's what I want mine to look like
Install done... fun fun... drove to it test everything... rechecked the connections... all good...
Now to park it again in the garage... where it sit... all alone... and rarely run this time of year...
TBh... I installed this so I can check the transfluid easier...
Ok yesterday I put in the GH IC, xdi-35, mds coils and ajp 93 tune to match. The IC was not too bad as I was about 4 hours running solo with a lot of interruptions. the coils, and sp 542's are the easy part. The hard part was the fuel pump. I will have to take it off and re mount it as I'm getting a small oil and fuel leak. really struggled with getting the high pressure fuel line lined up. anybody have some tips?
It runs supper strong for just the 93 tune and grabs RPM clean and fast!
Can't wait until it warms up to start revisions on the E30 tune!
You have to slightly bend the fuel line... it should line up clean in the ball socket and the nut to tighten it should easy to screw on. Sometimes it takes a couple times to get it positioned correctly.
For the h.p. fuel line, did you apply engine oil to the flare nuts and torque to 24 lb-ft wait 10 min and torque to 24 lb-ft again?
Well there you go. You needed ****, a whole ugaa wait and then the dugga.I did not. I gave it about 3 quarter ugga dugga and then sent it.
Looks sharp!
All that effort will reap dividends of happy ownership for many miles to come.
What model year again?
2012
Cleaned out stock boost control solenoid and plugged my intercooler after i drilled a hole in it last year. 1/4inch hole was causing boost issues and Brad seen my boost issue on the datalog and narrowed down my search. Between cleaning out solenoid and plugging hole, it made my boost pulse go away finally.
You're a BEAST man! Thats a lot of work for one day. Well worth it like BPD1151 said! Excellent jobWhat I did to my SHO today. Was at the shop for over 8 hours put in new spark plugs. MSD coil packs, trans/motor torque mounts, front and rear shocks/struts, Axles, hub bearings, sway bar links, lowering springs.
The car suspension feels stiffer. Better reaction crisp clean takeoffs no hesitation You can definitely feel the torque mounts. But as I read from other guys It will slowly dissipate. The Stance of the car definitely stands out Love it. Going back in tomorrow. For radiator flush new thermostat four wheel alignment and PTU flush. Is there a specific type of fluid we should use for the radiator? And the PTU oil?
Here's some pics from today
View attachment 11792 View attachment 11793 View attachment 11794 View attachment 11795 View attachment 11796
