Sholab1
United States
Added the 170 degree from Torrie, I think I burped it properly. Fans kicking on at 212. Will be lower with tune.
Did it according to the post SHOdded either posted or quoted a thread posted back in 09/2014
http://www.ecoboostperformanceforum.com/index.php/topic,2280.msg56469.html#msg56469
I am going to let it sit to cool to see how it is. if all is fine with the burp. I will add the 3 bar Map.
Then I will add the 93 Octane 3bar tune and hope for the best.
Sholab1
United States
Quick question this is the 3bar why only one bolt.? Are there not 2? Or am I wrong
Sent from my XT1254 using Tapatalk
StealBlueSho
NA
Depends on the year... I think 2010-2012 has two and the 2013+ had one.
Sent from my Nexus 6P using Tapatalk
5 cents on a bolt goes a long ways when you sell how ever many thousands of units.
Sent from my XT1097 using Tapatalk
bpd1151
Lurking Around
SHOcago 'Burbs
Yep. Thus why they formed a guide pin there, and did away with that extra 5 cents or so, per unit.
Sholab1
United States
Loaded and have to wait for wife to get home have to run to the store. 5 more min to try it. Then to pickup a t20 to keep on hand if ever need to remove it for warranty work.
Different question why does sync do maintenance afterwards? To save something for ford or just normal? Or is paranoid kicking in, lol
SilverSH0
Not only 5 cents a bolt but also install time. Think about installing that sensor with 2 bolts vs 1 bolt and a guide pin. With 2 bolts you have to put the sensor in the hole, manually line up the two holes, and then get one bolt started without moving the sensor. With 1 bolt and a guide pin you put the sensor in the hole, rotate until the pin slides into the hole, and everything is lined up. Then you're only installing 1 screw vs 2 so you also save time there. There's a pretty good savings with that simple change.
