StealBlueSho
I always thought having two screw holes to use was a better bet...if you botch the first attempt there is always a backup.. even if having two screws is more expensive....Just sayin..Not only 5 cents a bolt but also install time. Think about installing that sensor with 2 bolts vs 1 bolt and a guide pin. With 2 bolts you have to put the sensor in the hole, manually line up the two holes, and then get one bolt started without moving the sensor. With 1 bolt and a guide pin you put the sensor in the hole, rotate until the pin slides into the hole, and everything is lined up. Then you're only installing 1 screw vs 2 so you also save time there. There's a pretty good savings with that simple change.
Sent from my Nexus 6P using Tapatalk
but yes I would rather pay the 5 cents. Have had 1 screw hole messed up already on this 2015.
