GotGrip?
Conversation Ruiner
Minnesota
Thick boi intercooler has arrived. Got a good deal on a used one, hoping to get it sorted this weekend.
GotGrip?
Conversation Ruiner
Minnesota
She looks a little rough. How about a size comparison to the current one?
Yeah its a little rough looking but it holds air and it was about half the cost of a new one, so there's that!
The cores are similar but the having short runs offers significantly better flow but doesn't cool quite as well. However since this will be paired up with the meth kit, I'll get best of both cooling and flow efficiency. I will definitely be comparing logs to see how much of a difference the temps will be but from my understanding its maybe 3-5% or so less effective on the cooling side but has 30%+ higher flow rate. Since I've outpaced the cooler I have and depending on my turbo situation later this will work for the bigger GH turbos down the road.
Angrymongoose
Omaha
IMG 20210424 224852776
Fun fact there is apparently a difference on the xdi EVOs for 10-14s and 15s and up. I was finally able to connect the low pressure line and snake it over to the e85 sensor. It aint pretty but its functional. I did also manage to run it under the throttle body so its not quite as bad as this pic.
I went with the inovate ethanol/temp gauge instead of the phone app option. Unfortunately it keeps giving me an e10 error like it doesnt connect/recognize the sensor. I have quadruple checked all the wiring and aside from a problem with the pigtail on the sensor or the sensor itself Im out of ideas. I ordered a new connector and pigtail and Im really hopin that solves my problem.
Car does pull considerably harder on the revised AO tune with the new pump though. Hopefully later this week I can try out the e30 tune.
I should also thank Lee for messaging me last night about my fuel line problem and helping out.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
That doesn’t sound like fun. I had no idea what if any differences would be with pump orientation with the newer models other than blocking one ignition coil. Glad @FiveLeeter918 could help you out! I hope you found the answer to the connector and pigtail you bought and get it all squared away!
Angrymongoose
Omaha
I had no idea there was a difference in years either, but I managed to make this work and it doesnt block a spark plug so that's a win in my book.
The gauge is driving me insane. Mostly because I see no reason it shouldn't work as is, and I hate just guessing and throwing parts at things to make it work. At least a new connector and wiring is cheap.
I really dont want to have to rip the whole setup out to exchange it if the gauge or sensor is bad.
802SHO
I agree. The sensor gauge is something I should add too. I have a ethanol test tube but still it would be nice to see it at all times not just once in a test tube.
Ecoboost_xsport
Sacramento, CA
Yeah, in 2015, the inlet elbow on the valve cover was moved upwards on the composite ones. The aluminum ones had that elbow sitting lower on that front valve cover.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
I had to do some digging to find the pics ai used but he should have no issues using it. Just gotta get a little custom with the routing.
@Angrymongoose, As far as the sensor/gauge, where are you pulling power from?
Angrymongoose
Omaha
This isnt my picture, but this is exactly what mine looks like. Found the information about that fuse being live only while the car is on, on the other ecoboost forum.
The gauge turns on fine and has power. It just goes straight to displaying E10 with a red status light. I tried wiring it directly to the battery as a test at one point with the same result.Ffba136274322439a429412e4383b366
Ecoboost_xsport
Sacramento, CA
The gauge turns on fine and has power. It just goes straight to displaying E10 with a red status light. I tried wiring it directly to the battery as a test at one point with the same result.View attachment 18546
May be too late for this, but here was my write-up for the same projects you are completing:
https://www.fortheworkshop.com/?p=230
Ashleycat
