Roman
Mi
If you haven't already, buy a cheap tire gauge and check the depth yourself. Even with improper wear, surely you'd get more than 3K miles.
I have a pretty good mechanic locally that I trust. Been using him since I was 16. Of everyone I've dealt with, I feel like he's the most honest. I still like to do my own maintenance. That way I'm not being overcharged for labor and I know I'm getting what I paid for.
This week has been a maintenance week for the 'ol truck. Oil/filter, coolant, transmission fluid/filter, spark plugs, air filter clean/recharge, and even replaced the ATF for the power steering. I'll still let my mechanic rotate my tires. I need to invest in a good torque wrench. I don't trust the cheap HF one I have.
Sent from my SM-N960U using Tapatalk
Yeah I work on my own car all the time im usually the only person I trust to work on my car, they are the same tires, they still have all my paint markings inside the treads all the way around they are pretty bad, took a look last night
fordfanstan
CA
SHO’s been on the back burner, and still will be for a few more weeks/months, but popped a tire the other day so in the meantime I installed Discunzolo mounts, changed oil, trans, ptu, installed 4theworkshop drain plugs, extended ptu vent line and then installed 2 new Firehawks.
CA3A419B 9C0B 4844 A855 534C080DCEA8 914A6230 A447 4C60 B7F5 A323101BED1F 777BA3F9 1A1E 4B3C 96A0 88CB476831B5
Roman
Mi
Zpak
Es Aich Oh!
The region, Indiana
Can you get a picture of the can for me? And did you do any prep work to make it “stick”
I wiped it down with acetone. The more coats the darker it gets. I did three light, and one heavy with the black and gave it five coats of clear. The dark goes on a bit splotchy but smooths out pretty well after a few coats.
Roman
Mi
Glad I saw this! Just put my order in to Anthony/Tony.
Sent from my SM-G988U1 using Tapatalk
I keep hearing that someone else makes them to?
DadMobile
Texas
Fd4830be3e52f5f69a738500613ec9ef
Installed H&R springs today! Picture isn’t the best since I finished at 11pm.
Getting the first strut back in was total pia but the second one went in quick! I’ll probably cut the rear springs down next week.
Roman
Mi
Thats crazy my buddies taurus has the same look his rear is higher than the front but my rears are almost tucked like my fronts! Idk what's different but mine sits lower for some reason
DadMobile
Texas
Damn thats lucky!
BweegN
Springfield, VT
Incorrect or different rear shocks??
Assuming both are H&R's?
Super curious what mine is gonna look like now!
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Still some factory rake even after the h&r springs in the rear. I bet even Roman has a tiny more wheel gap in the rear. Also Dadmobile has the thinner sidewall 35 tires so that also adds a little wheel gap. I cut my H&R in the rear and it looked much better after. I’d say still has a tiny bit of rake to it even after cutting them.
Ecoboost_xsport
Sacramento, CA
So just throwing this out there...nkt sure how viable it would be, but folks put Ford Flex H&R springs on the explorer to lower it even more...
...I wonder how much of a match or how viable that could be to use them in the SHO...idk...probably not, just thinkin out loud..
Michigan-SHO
Michigan
I can’t imagine them being shorter than sho ones. That wouldn’t make any sense haha but that might be exactly why they do it.
