SHO4Peachie
Missouri
Dropped her off with my brother to get TLC maintenance. It was like dropping a kid off for the 1st time - my heart broke. Hope he finds my detail list of do's & don'ts as funny as I did while writing it. :rofl:
Enjoy your day!!
yaycandy
Aerospace Engineer
Hanover, PA
Stupid tire, gotta fix a tire today. Light came on yesterday and it was at 16psi and filled it back up to 35psi.
84722D4A 5D8B 41FE 9FD3 276AD18E861F
Hopefully it is not leaking from the tire itself. On occasion, rust at the bead/wheel will cause a slow leak also, even if you do not have road rash.
yaycandy
Aerospace Engineer
Hanover, PA
Foreign object!!!! Rockin the dinky till i get this one plugged
E1F05B66 F1D6 4429 9B75 246F1BBD7454C274BDF1 C433 44E9 917A 69FD436BD656
351Blueblood
So if it could be drilled where would be the right positions to do it? Has anyone drilled in for a new drain plug?
Is it worth doing this upgrade?
Dude can you check your "conversations" here? I sent you mail. Thanks PS I used a 1/4 NPT tap way big enough for drain,
yaycandy
Aerospace Engineer
Hanover, PA
It took longer than I thought to cut through them with my cut off wheel. Went through a couple discs too
Im far out of context but why did you need to cut the rear springs? Mine came out with ease
Edit: nevermind i was reading back and saw you guys ment cutting down the h&rs. I had that done at install as i saw it was popular now with them on other forums
A8B899A2 4E46 418D B9A3 5663CDCF1237
Haha. I cut my PP springs to level the car originally. Still hated the leveled 4x4 look. Got my H&R's and it looked a lot better. However, it still had more rear wheel gap than I liked. So I cut the H&Rs. She almost sits how I like it. I still need to see if she settles more.
FOR THE RECORD:
You can cut the rear springs. You cannot cut the front springs.
yaycandy
Aerospace Engineer
Hanover, PA
FOR THE RECORD:
Im sure all 4 of mine were cut. Never did drag on anything. But i have maybe 3k miles on them and noticed the car is lower then when i had them put on. Maybe they will rub eventually on the front
markmoomnu
