Enybody know what I need to change the oil in the PTU Where it's located What oil to use? Where the drain plug is.
2010-2012 PTUs have no drain plug. Only the 2013+ with Performance Package get a drain plug (and cooling).
SuperPete
PA
Correct, I have 2014 non PP, just got my PTU replaced recently by the dealer and no drain :(
I can't drill it for drain because it under 2 year warranty unlimited miles...
Wsho
Sacramento California
So if it could be drilled where would be the right positions to do it? Has anyone drilled in for a new drain plug?
Is it worth doing this upgrade?
15SHOPP
Cincinnati
Loaded up my new GH tune (still have my AJP tune as well), swapped to synthetic oil and went ahead and did a trans drain/refill since I was in there.
Also installed the front Anthony D. mount since I was right there. Coupled together with my 18+ rear mount, it definitely makes for a clean shift. Can’t wait to install the rear one and break them in!
Ordered O2 defoulers to install those once I get my car in to modify the current FRPP catback - going to delete my 3rd cat and replace the current resonator with a longer Borla resonator with a built in Xpipe.
StealBlueSho
NA
Rattling in trunk lid fixed.... bolt from the rear spoiler came off... screwed it back onto the offending side....
/sigh...
76FoMoCo
Nampa, ID
What x pipe to add with ppe catted dps?
15SHOPP
Cincinnati
The Borla resonator has a built in X pipe. Since the FRPP exhaust was built by Borla, figured I’d stick with the brand. Ridding the car of the 3rd cat can induce rasp so that’s why I went with a larger resonator than what came on the FRPP exhaust. Also, the transition of 2.5-2.25 inch will be gradual instead of slamming into the stock catback/3rd cat ******. I picked up some additional flanges from PPE to build that piece back to the resonator.
I’ll be sure to post some eye candy once I get it done!
I love it. I did mine a while back and it does look much better! I also love this type of mod bc it doesn't cost any money, just a little time. Totally worth it.
Plus it is super easy to remove the rear springs. Took me 40 mins start to finish. Hardest part was cutting the springs.
markmoomnu
