Input shaft is lined up perfectly from what I can tell, but the damn things just won't go together. How much force does this usually take?
Also, the front motor mount stud is getting hung up on the subframe; would the re-install just go smoother if I disconnected the trans mount and tried it from that angle? It seems to be the only way this thing is going to go back together is by really manhandling the transmission into place.
is this true?
