Sleeper Nitrous Build
RiceeatingSHO
Travis R
Alabama
why not just get acquainted with using N2o on the 50 then 75 first?
100 is a rather large shot for the SHO application.
I will be working my way up, never fear. But there are plenty of examples of 100 shot SHO's running perfectly reliably.
RiceeatingSHO
Travis R
Alabama
RiceeatingSHO
Travis R
Alabama
Anyone have pictures of their install so I have some ideas? I'm assuming i can run longer vacuum lines than those that come with the kit, right?
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
I love that grin on your face. Run the 75 shot and if you don't think it is enough then up to the 100. You will be very suprised with the power increase...best bang for your buck on these car and suprisingly not to hard to handle either.
Don't listen to brian shotime2511, he is too scared to hook up the nitrous on his car. :)
Also, zex used to have a page online with the jetting sizes for different engines.
RiceeatingSHO
Travis R
Alabama
The Jets are labeled, I'm going to hook it up next weekend hopefully. I was going to extend the wiring harness but I bought the wrong guage of wire. Honestly I only know wiring basics so is this ok? I can buy the correct gauge tomorrow but I don't want to spend any more than I HAVE to. But I will if this is too small (18 ga).
Speedy_91_SHO
Toledo, OH
I got my kit used and had to buy vac line anyways, so Im not sure what you will need on the vac line. I dont have any pics, but I had the NMU on top of the trans kind of and had the vac lines running along the back of the motor. For the nitrous nozzle i just drilled a hole smaller then the threads in the rubber boot. I didnt have trouble with it coming out either, but I did mark what was front on it and checked it every once and awhile. For the line from the bottle to the NMU, I had SFC's so that came in handy to run the line through, i dont know if you have them or not. It is pretty self explanitory and mostly preferance where you want everything, it is your car. After you get everything hooked up, test that the solenoid is working properly when you go WOT. It is best to do it with the bottle off, but you can do it with it on. Dont have the nozzle installed into the motor with it on, have someone hold it POINTING AWAY FROM EVERYTHING/EVERYONE. Oh and btw, the ZEX kit is BY FAR the easiest to install.(NOS=NIGHTMARE) Have fun and be safe.
RiceeatingSHO
Travis R
Alabama
Going outside to clean up the airbox...there's plenty of room under the filter.
(What is the sensor that is threaded into the bottom of the airbox? IAT? I never noticed it until last night.
Just for laughs, anyone want to point out wich vaccum port and FPR vaccum line to use?
