RiceeatingSHO
Travis R
What have you done in preparation? Fuel pump, one range colder plugs, pulling octane adjustment bar...what else? I have rod bearings done and maintenance is good...
I'd go with a 155, 190 is too much unless you have an adjustable FPR.
The 89-90 models (like mine) can handle any pump (so I've been told)
The stock regulator has no trouble drawing down the rail pressure to these low levels with a stock pump, but experience has shown that even a 190 lph pump (at full voltage) is too much for the stock regulator, never mind a 255 lph pump – in other words, the regulator, even when fully open, has enough of an internal restriction in the main metering passage that the rail pressure will not drop to the low levels demonstrated above, especially at high vacuum levels, if a 190 lph pump or higher is used, and the pump overpowers the regulator. This means that the relative fuel pressure is too high, and you are flowing too much fuel into the engine at low load. The EEC will compensate for this by trimming fuel, remember the compensation, and lean out the rest of your fuel tables by applying leaning long term fuel trims. This is not a good thing, as once you get closer to 0 vacuum, the fuel system will work properly, and you will be back to ‘normal’ pressures. However, if the system has been ‘learning lean’ with the excessive pressures, your close-to-0 vacuum fueling may be now too lean, like WOT, after the EEC applies what it has learned during higher vacuum levels.
You can get intake fuel pumps meant for fox body mustangs and they will fit. You can get them cheap then because everyone and there brother has a Mustang. I paid 130 for my 255 LPM fuel pump.
Bizzy, when are you going to juice the ATX?
since no one has answered your question yet, i will.What have you done in preparation? Fuel pump, one range colder plugs, pulling octane adjustment bar...what else? I have rod bearings done and maintenance is good...
It's not just what you can shove in the tank that matters though. You have to remember about your fuel pressure regulators and the computer as well. Without Josh's FPR's even a 190 lph pump can be too much at load. You can go with a larger pump, however you will need to upgrade other parts if you do. Take a look at Josh's page for info on this. It's located here. Scroll down about mid way down, when you see "Want more tech info? Keep reading …" that's the part you might find interesting and helpful.
Here's a short quote from that page. It would benefit you to read the rest of it.
Also, my "stock" fuel pump was a 155 lph pump that I bought from Murray's. My mistake in calling it "stock".
We'll see how that goes. But I also plan on running some 109 with that as well, considering the SHO is tuned now. I may even wire the octane adjust switch up too for extra insurance. Actually, I think the car may be on the rich side of things now, as I have 9% more fuel over what the nitrous adds.
