shomstr of boston
donnygould
malden,ma.
after my sho is hot and i shut it off it wont start until it cools down again.it has no problems while running and if its not running long it starts up no problem.is this the crank sensor? could it be that its another sensor that is more heat related.please help 1994 atx.
Dr. Tweak
Mad Scientist
Northern Vermont
Yeap, prolly the CPS.
Try doing a search, that'll help you a lot.
And check out the SHOPP website (link in my sig)
Yamaha V6
SHO Enthusiast
Rhode Island
Heat related, replace the DIS first before diving into the Crank Sensor. Quick, easy test.
SHOguy 92
Duluth, MN
Take a look right in front of your throttle body it has a greyish playtic cover over it, it's where all your spark plug wires run too.
PAracer
West Chester, PA
That is a description of the coil pack.
The DIS module is the unit that is screwed to the intake balance tube. It has the words "Motorcraft DIS" on the side. Also, do you have a leak at your water pump? A leaky water pump will cause the CPS to die in the same manner that you are describing. If your car has not had it's 60/100k, this is your que to start doing the required maintenance.
Bizzy
What he said.
You should run the EEC codes when the engine is unable to start and find out what is not doing its job. See the link in my signature for the test procedure that only requires a jumper wire and the ignition key.
I am wondering if the fuel pump could be involved in this problem. When the engine won't start, can you hear the fuel pump in the fuel tank whine when the ignition key is turned to ON?
