sho shop udp belt size
bigblock
cali
i tried to search but keep getting this fatal error crap. anyways, i got my hands on a sho shop udp set and need to know what belt sizes i need.
thanks
Art5
white plains, NY
I have under drives for my 91, just bought new belts the 4 rib is K040510 and the 6 is K060455
Do you think they are the same for gen2 as well?
I complitely forgot that I have UDPs as well, and I have to change Alternator belt asap.
Art5
white plains, NY
thanks a lot guys. Belt is so bad, I should've changed it last year, my a/c clutch fell off too, so I have to change a/c compressor as well.
jayro
Auburn, In
I would stretch a string around them after you install. Different udp set ups may use different size belts. I had the sho source crank pulley one and I think it uses a different size belt than the sho shop one.
jayro
Auburn, In
Anyone running both the SHO Shop set and the SHO Source UDP? :munch:
I just have the sho source one. Wouldn't that REALLY underdrive your accessories? There are some power gains to be had from an udp set up, but isn't saving your accessories the main reason to have them? I just didn't want to fry my alt when I bounced off my 8k rev limiter.:evilgrin:
shobroooo
