vortex2450
Buying Parts...
I'm in a bit of a panic here.
Was driving the SHO home from work, made a stop to get gas, pumped $20 of non-methanol v-power , since my mileage sucks with everything else it was worth a shot; proceeded to start the car and had to crank it over for a solid 10s alternating the throttle tbefore it started. Weird but I figured it was time to be getting home in city driving environment. stop-go lights on a very busy thoroughfare. Idling just fine at a light, 800rpm and voltage at a solid 13v, oil pressure of 15psi. Purring and then it chugs for a split second and dies. Won't turn over at all when I tried starting it back up.
So I had to jump out and push the car to the turn lane and navigate a double left hand turn into a busy mall entrance, it was hairy. Made it to a parking spot at this point. I immediately unpacked my tool kit and went to work.
-Hit the starter solenoid while my friend cranked. Engine just seems to "jam" up and not want to turn over.
-Took off crossover tube and upper timing cover and checked the belt tension, which was good.
-I Was also able to determine the cams were timed correctly. Checked the tensioner through the access door and it was tensioned and secure.
- I tried cranking on the crank pulley with a 1/2" ratchet but couldn't budge it with just the ratchet handle as a moment arm.
-Oil is healthy looking and at a good level.
- No CODES. just a 111 confirmation.
- Got a jump and it didn't improve any part of the situation.
More background:
-Tri-Flows installed a month ago. Had to leave 6 valves out of spec in the front head due to a lack of thicker shims.
-Noticed an rpm related tapping @ 2500+ rpm about a week ago. Attributed it be the either the over loose shims or perhaps a chain tensioner.
-Starting issue is come and go since cam install as if the engine was flooding. Cut injectors via WOT throttle and it'll crank up fine. Figured a tune would help here.
My plan of attack is to replace the starter and cross my fingers.
I also suspect CPS death. Or perhaps more sinister issues. I wish I had taken video, I might tomorrow.
Any thoughts?
-Josh
More background:
Any thoughts?
-Josh
