SHO cuts off while driving
william
va
I have a 95 SHO, which has repeatedly cut off while driving. The crankshaft censor was replaced once, but not to long after the problem continued. Most recently the ignition modular was replaced, which didnt solve the problem either. I also read a post on this board where someone was having the same problem and replaced the crank shaft censor. I guess i am asking if anyone knows if it is likely for the crank shaft censor to go bad multiple times, and could their be any other possible causes for the car to cut off while driving. Sorry if I made this to long. I would greatly appreciate anyones help.
Thanks
Bigjoey71
Gurnee, IL
I had a similar problem in the past with my car. I replaced the CPS, but that wasn't the problem. The problem turned out to be the fuel pump relay. After that was replaced, the car was perfect.
joe
jthomas68
Area 51
Was the waterpump changed at the same time as the sensor?It goes bad because of a leaking pump 99% of the time.
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:
Sam
Fredericksburg, VA
I agree with Jeremy on the CPS/water pump; if engine stops suddenly that's the most common problem. The other likely cause is the fuel pump; if engine sputters/bucks it's probably a bad fuel pump.
FAST4DR
William,
I have a 95 MTX that does the same thing once in a while. I am hoping it is the CPS or whatever you call it below the water pump. When I do my 60,000 maintenance soon I plan to replace all the sensors I can. I have a new fuel pump and that was not the problem, but I guess it could be the relay(s) for the pump. I hope changing the various sensors will fix it. Where in VA do you live? I am only a couple hours from VA.
William
www.wclewis.com *** YAMAHA - SUPER HIGH OUTPUT BADGES ***
95 Red/Tan MTX -- Torque Limiters -- K & N panel -- PIAA Driving Lights -- PIAA platinum super white's --
F&R Strut Tower Braces -- Subframe Connectors -- 13" Baer brakes -- Shoshop Y-pipe --
17x8 Fittipaldi Tubolares w/235/45-17 --24 & 26mm F&R Sway bar w/poly
Sachs Clutch -- 255lph Walbro Fuel Pump -- MTX Drain
Stereo - Clarion AutoPC Navigation system
Avital 6500 - Auto Start & Security
[This message has been edited by FAST4DR (edited 01-20-2002).]
ManySHOs
South Jersey
Thanks
When you turn the key to the run position, but not on, does the fuel pump sound different? It makes that whirring sound as it primes. You might also have a dying fuel pump. Something else to consider. I believe that you can check pressure at the fuel rail. I usually just replace the pump though. (However, I know that my CPS isn't bad)
Ian
