runs way too rich, need help
Detenator
Rockland, NY
So im driving down the road, with my friend behind the wheel, and he is getting a kick out of how much power my SHO has, he is very impressed, even though he himself drives a mustang. Hey Pete, he says, it has a great power boost from 3900 to 5000 rpm, and he shifts at 5k a few times. Then he pulls to the side of the road, im like, whats up? he's like, your engine is dead...
we quickly diagnose it to be the timing belt.
now i know that this is a non interference engine, so the valves did not self destruct, and so we drag it home, and i figure, 45 bucks new belt? 400 bucks from mechenic? i opt to do the job myself. takes me a while but in the meantime i get a lot of experience
so then im finally done (at like 2 in the morning), im real happy, i take it out and do a few drag strip runs at a local parking lot and the thing seems to have more power then before. so i take it home, and fall asleep. i show it off to a few friends the next day. I remember hitting a rather large puddle one time. Big deal, i think, ive hit puddles before. the day after that, the thing idles with way too many vibrations, doesn't go above 40 mph, gets 10 gallons per mile, check engine light comes on, and in general is very very weak. I think maybe it skipped a tooth, so i tear it appart (takes me an hour this time, concidering all the experience i got). There dots on the pulleys are right where they should be, the belt is a lil loose though, so i tighten it. I put it back together and it still gives me trouble. so i buy a code reader, do a code scan and it tells me that the oxygen sensors are way out of range. well, no duh, something is dumping way too much gas into the engine. thats how far i got on my own. after this i have no clue where to go, so i turn to this forum.
Could it be that it skipped a tooth and bent a few valves, which are not closing all the way?
could it be that the puddle messed up the engine computer or something else which opens the fuel injectors too much?
could it be that the cold water on a hot engine warped the heads or block and now compression went out the door?
maybe water entered the gas tank and to make up for it, the engine sends in more gas?
or the water trashed the o2 sensors and now they tell the computer to dump more fuel in then is needed?
or maybe the wet clutch doesn't grab like it used to.
I have no clue what to do from now on and i need the advice from someone that maybe has experienced this problem before and can tell me what needs to be done. Please, if anyone can throw any advice my way i would appriciate it.
revhardSHO
Seattle, WA
Sounds like something electronic to me. Since those O2 sensors are outof wack. Possoble bad o2 sensors??
I know the ECT fails occasionally resulting in rich condition. It is recommened to replace every 100K. How many miles on your SHO?? \
good luck!
Silas
What, exactly, were the codes? The story is in the codes. Tell us your story. I agree that it sounds like an electrical control system problem.
Detenator
Rockland, NY
Those engine codes were
KOER 4-1
Key on 7-7
Engine 7-4
Running 5-2
KOEO 4-1
Engine 6-7
Off
4-1 HEGO (HO2S) Sensor out of range/ Lean
[which is kind of wierd because i thought it was rich ... i mean all the gassoline is going somewhere the car gets terrible mileage.]
7-7 WOT not sensed
[so i forgot to step on the gas]
7-4 BOO Break on off
[so i forgot to hit the pedal]
5-2 PSPS power stearing
[i forgot to turn the wheel]
6-7 this is an interesting code
it means different things depending on different conditions
With the engine off it means MAP manifold absolute preassure sensor failure
in continuous memmory it means Clutch switch circuit failure [this is probably the cause, i hot-wired the clutch]
for trucks it means the ac compressor switch failure
and it can also mean a fault in the neutral switch on automatic cars.
That was a very unusual way to present the codes. First, what year is your car. Second, only if your car is model year 1991 or earlier would you be looking for 2-digit codes and I have never seen a PNP switch error on a manual transmission SHO. Could you read them again and present them in the category in which they were generated?
For example:
KOEO
Hard Faults: xx, etc.
Memory Codes: 41, xx, etc.
KOER
41, 77, 74, etc.
