Runs bad on tune
Zinprogress
I just recently purchased a tuner with a 3 bar and plugs from a well known vendor on these forums for my 2013. With the tune, the car falls flat on its face when getting into boost and throws a cylinder 3 missfire. Stock tune and map and it runs perfect again, after talking with the vendor he assumed the 3 bar was faulty and sent me a new one and same thing.
I rarely beat on the car so I was trying to drive it more aggressively on the stock tune to verify there wasn’t an actual issue that is more affected by the tune. I noticed that sometimes when getting into boost the car feels like it’s lagging before it really hits. When looking at the data it’s like boost hits but there is a big delay before power enrichment starts to add fuel then it takes off. Went to do a smoke test and found the turbo inlet pipe is leaking on the front turbo where the hard pipe attaches to the soft coupler, but being speed density I wouldn’t think that’d really affect much. Will be ordering a new one.
Things to note-
Car is extremely well maintained, all fluids changed. Plugs and 3 bar are motorcraft. Intake valves are clean. I tried swapping coils with my Explorer platinum with no improvement. Commanded fuel pressures closely match metered pressures. Vendor verified tune was correct for my car and yes I swapped the map sensor on top of the intake.
Majestic
Things to note-
You positive about that?
Zinprogress
yes positive it was the one on top of the intake. Sent pictures to the tuner/vendor to verify
Majestic
Just making sure you changed the MAP underneath the engine cover. I've seen too many people change the wrong one.
Zinprogress
Yeah I saw a bunch of posts on that. He had me put the 3 bar in the pre TB port and the pre TB in the intake for testing purposes which ended up with him sending the new map. I’m kind of at a loss on this, when it first happened it kind of felt like spark blow out. I have a bunch of tools for looking at data but on HP tuners there are an insane amount of PIDs and a lot of them don’t yield data. I have the SCT but still figuring that out and an old solus pro and a new autel d1. Just don’t know what to look for at this point.
And just to clarify, tune with 3 bar drives perfectly till you start really getting into boost.
kryptto
South East, Florida
ok not saying the vendors name is concerning, share since you are also claiming that you sent them pictures. the 3 bar mounts on top of the intake that runs to the individual cylinders and NOT the pre throttle body on the charge pipe to the throttlebody. if you changed the one on the charge pipe and not on the top of the engines intake then that would be a mistake.
I would ask the tuner if they can write a tune for the stock MAP sensor and eliminate a software/hardware issue.
Zinprogress
Gearhead.
Majestic
That is the correct sensor, and if you are using GH, I'm sure he can figure out what the issue is.
Zinprogress
He sent the new sensor and I left town for a week so it took a while to try it. I emailed him but haven’t heard back for a while, I assume things got busy with the 4th and all that.
Levcam517
NJ
Did you check the gaps on the spark plugs? They recently sent me a set and the gaps got all messed up during shipping. One was even 0.020. Only one was correct at 0.026. I had to send it back and they sent me a new set.
Zinprogress
I did check the gap on the plugs all were 0.026. While prepping the car for a 2,500 mile trip I decided to take all the plugs out and inspect and sure enough cylinder 3 had a crack in the porcelain. I’ll be gone for 10 days so I’m going to see if Matt can ship me a pair of plugs to where I’m staying in Wyoming. The fuel will be a lot better there as well, it’s a shame because they have a bountiful harvest of e-85 and I’d love to run this thing regularly on e-30.
IMG 6326
FIREMT1977
