Eric, you've probably read enough of thread to know that the OP and I are in the same boat. 2 questions:
- What indicators allow confidence that the injectors are the issue versus plugs and coils?
I'm currently having bad stumbling, mostly at low end, and getting no misfire codes, or any codes at all! When I had LIM out, I had disconnected fuel lines and left fuel rail on, thinking this would reduce the chance of needing injectors or seals from the trauma of popping rail off and back on. I noticed the injectors could spin between fuel rail and LIM but still felt tight. Upon reassembly, I put key to start a few times and let fuel pressure build. There were no leaks or hissing and I did a sniff test all over intake and fuel lines and didn't detect anything. These are original injectors. When I cleaned LIM I used a solvent that claimed to be safe for intakes and cats. Is there still a chance that I botched one or more of them?
- From your experience, can a gen 3 run with 3 misfiring cylinders?
Local dealer told me I had 3 missing - 6, 7, & 8, all on front bank. Whether this was a cop out or not I don't know since they refused to run full diag and therefore didn't access rear bank, but when connectors were removed from these 3 one at a time, I didn't really notice a difference in stumbling. Perhaps it would be hard to tell. I have 8 new coils on the way and will replace plugs as well. I guess if it's still stumbling bad after those, the injectors are most likely culprit(s)?
