Rod Bearings and Piston Rings?
DeepPower
Searchng4Truth
Texas since 2013
With 300K on my '89 SHO I'm thinking I should have my trusted mechanic replace the rod bearings. I understand this is done by removing the oil pan.
Not knowing what's available down there, can anyone tell me if it's possible to drop the crankshaft and pistons to replace the piston rings at the same time?
Devin
3.Slow
Pacific Northwest
Sure, why not? Though I'd rather take them out the top or pull the whole engine.
CRW 4369
sperold
Last to Know
I would say it is a bad idea to try to try to drag the pistons out the bottom to re-ring your pistons.
Very often the webbing for the crank bearings gets very wide and may not let the piston come down "straight" for the full depth of the piston. Also, the ring compressor will have to be fit in that same space when you re-assemble, and that sounds even less possible.
No real experience on these engines, but on the ones that I have, it would not be possible.
By the time you dis assemble the front of the engine to get the belt off, and the flywheel at the other end, you will have more time invested when you compare it to pulling the whole assembly.
Take the car to a place that has done the rod bearings before, I have heard people bragging they could do the whole thing in an evening, so you must gain a lot of insight by doing it once before.
Don't do any work that is not required, mileage alone is not a good reason to get the wrenches out.
Don't do the two operations at the same time (rod bearings and rings).
And remember, usually you don't need rings as your best bet is to remove the carbon behind the rings with a land cleaning tool.
And don't loose sight of the fact that gaskets and parts are harder to source than ever right now.
there is no way to pull the pistons out the bottom without destroying the block. The only way they come out is the top.
DeepPower
Searchng4Truth
Texas since 2013
Thanks, everyone!
Well, while down there, is there anything else worth replacing?
DeepPower
Searchng4Truth
Texas since 2013
I see your from Texas. I know Texas is large but if your willing to travel to Dallas I strongly suggest
http://northtxperformance.wixsite.com/northtxperformance
Tony is an experienced mechanic that knows SHOs very well. He is also a SHOForum member.
It's an experience I do not wish to repeat. Tony will never, never, never work on any car of mine again and strongly recommend not taking any car to him.
dan.delargy
