Rod Bearing Question
SHO_N_GO
95 MTX
Fort Rucker,Al
I'm replacing my oil pan seal because they are leaking since i'm in there i'll be replacing my bearings but i'm not sure which size i need, my car is stock besides a K&N filter, SHO Source Catless Y-Pipe (not installed yet) and Dynomax Mufflers. Car is a 95 has 185K and a MTX.
These are the sizes from RCM STD, .25mm, .50mm, .75mm under
Which ones do i need?
Off Road SHO
Moderator
Actually, with all due respect to Ken, you will need to replace them with like for like. If you have standards in there now, replace with standards. If you have .25mm's in there, replace with .25's. The stamping is on the outside (non wearable surface). If you're absolutely, positively sure that your engine has not been opened up since little Japanese hands put it together, you will only need standards.
Tom
Devin
3.Slow
Pacific Northwest
On my rebuild I plastigaged a set just to be safe, even though there was normal wear on my bearings. I figured why the heck not since it takes a just a bit of patience and one more hour.
