Removing EGR valve, and ground strap.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I'm trying to perform the upper 60K on a 94 ATX. I've got all the vacuum hoses, and coolant lines disconnected, as well as all the bolts loosened. I can't for the life of me remove the blasted ground strap. I'm using a 15mm socket on the nut, but I can't get a wrench on the bolt. Any ideas? Also with the EGR valve, am I removing it from the intake, or removing the nut that connects the valve to the line (if that makes sense). Thanks!
projectSHO89
SHOless In St L
As for the ground strap. you may need to put wrenches both on the nut and the stud at the same time to get the nut loosened. It's a tight fit in there....
As for the EGR valve, I always remove the valve from the intake and just leave it hang. Just make certain you have a replacement gasket on hand. Don't forget the clean the EGR ports while you have it apart.
Steve
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Steve
I can get the nut to turn with the socket. The problem is, I can't get the wrench on the stud to keep it from moving with the nut, as I turn it with the socket. Always the small crap, I swear! As for the EGR, I'll do just that and remove it from the intake! Thanks for your help!
SuperHO
Mental Patient
St. Joe, MI
just unhook the ground strap from the firewall....that'll save ya some trouble.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I thought of that too, but it seems as if there's a wiring harness that's kinda wrapped around it. I'll go take another look in a couple of minutes, but thanks for the suggestions!
SuperHO
Mental Patient
St. Joe, MI
even if the harness is wrapped around it, you can just slip it through.
313tiger
