revhardSHO
First, on the way back from picking up the car, the left rear brake started sticking for no appearent reason. We pull over and *try* to figure out whats going on back there. The has basically all new pads and rotors all the way around. The rim was really HOT (you couldnt touch) and the caliper was sticking for some reason. I opened the bleader valve and just a little fluid came out (few drops). We tried to bleed it for quite a while, but to no avail. No brake fluid was comming out. As a result, we just left the bleader open so it wouldnt stick (probalby not a good idea, but i havent had a problem yet, and brake fluid level is still norm.). SSolved the problem for the time being. Today, the same problem cropped up on the right rear side...fixed it using the same method as above. Obviously its not safe to drive, but braking seems to be okay. It seemed to happen after hard braking to a stop. What could be causing this on both wheels? Pinched line???? Thanks for any advice!
Silas
Silas
