Re-ring set
bri26064
Has anyone here use the Autozone Hi-Tech #FO3.0RR01 re ring kit. I would like the get the better set but there is no way I can afford it right now and I need my car. Thanks for any help
ManySHOs
South Jersey
TRSCobra said:
I didn't think these engines had any ring wear. :p
Depends on prior maintenance. I have a 3.2 block in my shed that's worn past spec. Going to the scrap yard when I get a chance!
Ian
bri26064
because my compression tests were
1-180
2-185
3-180
4-125
5-175
6-150
And the low numbers jumped up after I squirted oil in them. Also the engine has been on the edge of overheating. Yes I replaced and checked everything and yes the temp gauge is working. I just need the car to last me another year. So, I ask again. Has anyone used the Autozone Hi-Tech #FO3.0RR01 re ring kit? Is the quality bad or is it an OK kit. Thanks.
SHOtimer
#2910
Santa Clarita, Ca
Ian
Why not rebuild it, or sell it to someone to rebuild?
Doug
