QUICK! identify this part for me NEWB!
UltraH
Wappingers NY
ok i was lookin under the hood today and found somethin out of the ordinary i thought... what is the silver box located under the intake arm(between the tb and airbox) with a long plug coming from it. I have an ATX. . . and it wasnt plugged in.... i looked quickly thru my chiltons.... ill look again but ill hope to hear from someone... if someone has a engine bay pic of a atx ill point it out better.
it had a few pins corroded and when i plugged it back in it smoked like crazy for a few seconds then i unplugged it. Now i cant get the tranny out of "P" before this happend when it was unplugged i could atleast shift thru the gears but it wouldnt shift out of 1st. (Atx) :bonk:
UltraH
Wappingers NY
i dont know why that would cause my tranny that was already messed up to now not work at all...... the silver box has a long plug facing the driver side if your looking at it straight on...
jaded93atx
Chicago
That sounds like its deffinately the cruise module on an ATX...I just fried mine, in my case with it unplugged I have no horn or cruise control, but at least I have brake lights.
UltraH
Wappingers NY
yea its the CC... and i did blow the # 1 fuse... mines stayin unplugged but i still have my horn?.... thanks guys.
jaded93atx
Chicago
Maybe losing the horn with that harness unhooked is a 93 ATX thing, I'm still at a loss as to how that large amount of brake fluid found its way in to short out my coupler in the first place, its a good 6-8 inches away from the resevoir and my brake fluid is at the max-line were it always has been.? I'm kind of just writing it off as another case of the crazy sho gremlins at work.
rangerj
Brunswick, Ohio
Check your clockspring guys. The clockspring is behind the air bag and provides the connection for the Cruise Control, Horn, and one other thing I cannot recall at the moment. Oh yeh, it is the air bag. So, If you are going to do any testing it would be wise to disable the air bag as a safety precaution.
If two of the three items that are supplied current through the clockspring do nopt work, e.g. the horn and the cruise control, then the clockspring is the prime suspect. rangerj
WARNING WARNING WARNING!
AGAIN, DISABLE THE AIRBAG.
