Help Me Identify These Wiring Clips
ShoSean95
Vancouver
Good afternoon everyone, hope y’all doing well.
I’ve come on here to figure out two lost connections on my engine wiring harness. I’ll add some pictures at the end. I’ve found my two spout connections and the egr connection.
There is one connection that is located just off the engines wiring harness beside the engine ground strap (firewall side), that clearly had the other half’s plastic housing still stuck inside that I can’t find where the other half would be. My current suspicion is that this is a ground itself as there is another one that looks incredibly similar leading to a ground located beside the battery.
The second connection is off the engine’s wiring harness where it branches off to the maf connection. This has been zip tied to the harness.
Any info or a picture of your engine bay would helpful cheers
The one in photos 3 & 4 is unused.
The round one appears to have part of the mating half broken in it. You should find the mating part somewhere down on the passenger side firewall area. If I remember correctly, that connection is part of the abs system.
ShoSean95
Vancouver
Wonderful thank you !
Would that connection clip actually be important or just that the two wires mate together ?
zoomlater
Seattle, WA
the connector on the right side would be the one you are asking about
shootinirons
