Pulling an engine
SHO_DOODmorrris
Owner & Fanatic
Alberta
Hi guys, Quick question, do i have to pull the engine with a crane or can i drop it below?? im thinking only with crane but i dont have one, any ideas on getting it out? 89 stock engine. thanks ahead of time :thumb:
-Mitch
Minnesho
i was wrong
MinneSHOta
i did my trans in a few days by myself in the driveway. i would imagine the engine would take a little longer, but i was also taking my time.
SHO_DOODmorrris
Owner & Fanatic
Alberta
thanks, if anyone else out there has any ideas or pictures or how to's please post them. thanks a bunch
-Mitch
e_clouser
04DrpTopGT
Near Harrisburg, PA
I pulled the engine and trans out of my 92, then pulled the trans out of my 94 and stuck the 92 trans in. Took me one FULL day. It is a straight forward job if your up to it
yamahaSHO
E85 whore
Arkansas
It took about 4 hours for me to disconnect everything on the motor to pull it from the top. The only time I had help was taking the hood off and actually pulling the motor.
Shoaz
Studly dood
Scottsdale, AZ
If you only want the motor, as Jason sez it's about a half-day job to take it out the top. Dropping it out the bottom requires dropping the tranny and subframe, and then you'll need a front-end alignment, deal with the steering rack, etc. It's less work taking it out the top unless you want the tranny out as well or want at some other things.
Black '93
Guest
Lakemoor, IL.
3-5 hours out the top.. Easy job. Just lots of disconnecting. Put towels over the front end and the fenders so you don't accidently ruin your paint if it's nice and you bump it with th motor.
1993MTXSHO
Its a Taurus...
Jersey
yeah definitly dissconecting and takign everythign out of the way was the hard part. Just make sure you unbolt the flywheel and make sure you know where all the bolts are, i was trying to putt one out of my car and i didnt know about the 2 bolts from the passenger side.:thumb:
SHO_DOODmorrris
Owner & Fanatic
Alberta
Sellinthecarpics009 thats the front end. im taking the engine another guy takes the tranny and the other guy wants the rest of the car - the chassis so front end alignment dosent matter... lol the previous owner hit a deer but engine has 195 *** km/s on it
SHO_DOODmorrris
Owner & Fanatic
Alberta
p.s do i have to cut the subframe or is it held together with bolts???
Minnesho
i was wrong
MinneSHOta
there are 4 bolts holding the subframe in. i guess i should have said it took me a few days in the driveway, and that was with work too so I didnt have much time each day.
