pulled codes &
jimbobzsho
westland mi usa
pulled the codes and this is what it came up with #1 is 49 spout signal defaulted to 10 degrees Btdc;spout ciruit open..#2 66 maf sensor input is less than minimum voltage...can someone pleas translate.
jimbobzsho
westland mi usa
I went to shotimes and looked up the codes but they dont have what the codes mean i dont understand what codes 66&49 are trying to tell my
The 66 code reveals that there is a low output from the MAF sensor. It is either a problem with the MAF sensor elements or the connector or wiring to it.
The 49 refers to the spark output circuit being open. Check to make sure that the jumper plug is fully seated in the SPOUT connector near the EEC Test plug by the passenger side firewall area. I have not had first hand experience with the 49 code, so I would like to hear what you find.
Scott
jimbobzsho
westland mi usa
ok thanks Scott i put a post on the contacting sho members you can disregard that post ill let you know what i find out
thanks again
SilverSHO
cartersville
I believe the SPOUT connector is up on the firewall behind the starboard strut tower. Now that I finally have my car up and running, I can go check it out and see why I get the SPOUT code. I'll let you guys know what I find.
Nick
Lt. Titanium 90 135k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop torque limiters, Cherry Bomb Turbo II mufflers
AIM: loudog6491
