PTU Temps
jazzplr
Lafayette, IN
Assuming that I've entered the right PID and formula in Torque Pro, is 170-185 degrees normal for PTU temperature during normal driving?
Bronco2fan
Texas
You get all that info from an app on your phone? I gotta start putting this stuff on mine, that's awesome.
Sholab1
United States
Using a cheap Samsung Tab-E and a OBDLINK MX adapter. Running tourqe pro, it's on Android store.
http://www.obdlink.com/mxbt/
Seems quite a bit quicker than the cheaper 15.00 units out there.
Sent from my SM-G955U using Tapatalk
Bronco2fan
Texas
I'm reading about it now lol. 5 bucks isn't bad at all for something that good.
Sent from my LGLS991 using Tapatalk
Sholab1
United States
I think I used a Ford add on from them for some ford specific items, put was added manually, there is a PID link somewhere to a list of pods on one of the ford forums. Someone will post it. I have it at home but am traveling all week. One of those 1k mileage weeks again, lol
Bronco2fan
Texas
Ok. Thanks for the info. Drive safe.
krewat
Long Island
Yup, and using a $25 or so dongle off of Amazon for the interface to OBD-II.
I even used this cheapo thing with Forscan and turned off the double-beep when you get out of the car and close the door with the engine running.
Cool stuff in this day and age.
Sholab1
United States
Can we disable the double beep, even though we keeps swapping between factory and 2 of Torries tunes?
krewat
Long Island
I don't see why not, It's the BCM (body control module) values that I altered to turn it off. Tunes shouldn't touch the BCM.
For my 2016:
Double honk:
726-16-01 0211 57 as built
726-16-01 0201 47 (changed to)
AWD gauge: Change first 8 to B
720-01-02 8AFC-4CF0-3F2B as built
720-01-02 BAFC-4CF0-3F5B (changed to)
You need to get your as-built info from Ford and tweak the bits necessary. https://www.motorcraftservice.com/AsBuilt
Sholab1
United States
For my 2016:
Double honk:
Double honk make me want to jump up and down on the hood. Lol
Sholab1
United States
47 or 57 was not in bold so just want to make sure
krewat
Long Island
Especially when you forget something at 5AM and go back in the house to get it.
The last 2 digits are a checksum - they will change on their own. I would check your as-built data before you do anything, to make sure the numbers are the same or close. Your 2015 is pretty much the same as mine. I don't think anything really changed between 2015 and 2016, except Sync 3
bmytych
