Bizzy
- Joined
- May 1, 2001
- Messages
- 13,222
- Reaction score
- 1,462
Updates?
SonicRiot said:If the clutch or TOB hang up on the input shaft splines, there will be no shift and no grind.
masho95 said:Wow sorry for no updates for a while.
Drained out all the old fluid I could, and installed some new Royal Purple. Same issues are continuing to occur. Can't go from a stop right into any gear except 4th, and even then it's not as smooth as it should be, like when the car isn't running.
I've also noticed that when in neutral at a stop if I push the shifter towards first gear it won't go in, BUT if I slowly let the clutch pedal up, it won't go into gear and it DOESN'T grind at all. The clutch pedal can be fully released and it's like it's in neutral. Almost like there is something physically blocking the shifter from going into gear. I'm at a loss.... obviously it IS clutch related, since the car will smoothly go into any gear from neutral when the car isn't running.
What would cause this? I mean the TOB ride on the quill sleeve and doesn't touch the input shaft spline, correct? I don't remember anything unusal from the installation. I left the quill sleeve alone since it was securely attached to the shaft.
One of my friends is Harley Davidson tech (no idea how it relates but I thought I'd share) and he suggested that the clutch disc wasn't perfectly aligned and could cause it to not fully release. I used the clutch alignment tool for whatever benefit that was... I centered the disc by hand anyways feeling along all the open edges of the PP to make sure it was even. Perhaps it did slide or the alignment was off to begin with, who knows, I thought it was even. I'm just bummed by this whole deal because I don't want to have to drop the tranny yet again, and this is my daily driver.
93rev2sev said:This happens when the cable is too long. Take out the under carpet plastic-backed sound deadener. With that removed, you wil have another inch of pedal travel. Do this first as you will be wearing the shit out of your blocking rings on every shift if I'm right.
93rev2sev said:Conventional wisdom says that the clutch is not fully dis-engaging. This happens when the cable is too long.
masho95 said:Are you saying that the clutch cable got stectched out somehow when I replaced the clutch? And I should get that extra inch of pedal travel immediately?
masho95 said:As for getting into reverse, I can go from 4th gear then to reverse from a stop.
masho95 said:One more thing to add...when I'm already driving (not at a stop) I don't have any issues shifting from gear to gear. I don't think it's exactly as smooth as it should be, but I'm not jamming it from gear to gear to get it in. Would this relate in any way to my problem?
SonicRiot said:If the clutch wasn't aligned, you wouldn't have gotten the trans back in with much ease. If it's cocked, your PP probably wasn't torqued down correctly and is now *****'d.
Try adjusting the cable.
93rev2sev said:When you did your clutch and put that cable back between the tines in the clutch fork, how much extra were you able to pull out? Was it real easy to pull enough slack from the cable to put it back over the fork?
The EASIEST way to find out if your cable is streached is to temporarily shorten it and see if your problems go away.
SonicRiot said:I never understood why a PP needed to be painted.
