Problem reading codes
jthod
Mr. Goodwrench
Lincoln, Nebraska
I have tried a couple of time to read the codes on my 'new' 93 MTX. The check engine light does work, it came on while driving a few days ago. I've checked the codes on my '90 several time without any problems. But this thing just won't spit them out.
The fan kicks on and the fuel pump primes, but nothing after that. My only idea is a bad computer, and I don't even want to think about that. This thing has enough problems.
Thanks!
jthod
Mr. Goodwrench
Lincoln, Nebraska
I don't know if this plug wold have anything to do with it, but I can't find what it plugs into. Computer related?
Dasd1jpg1
it's the one right in the center between the EGR plate and the brake fluid res.
PaulNasers
Bigelow,Mn
If u have an O'reillys they have the obd1 and obd2 tester they will let you use it for free they dont even watch u do it(so it isnt annoying)
jthod
Mr. Goodwrench
Lincoln, Nebraska
I'm using the paper clip method. The car is not road ready, and the places that rent them out have a $250 deposit, that I don't have.
I found a cheap tester at AZ, $30-40, but works the same way as the dash light, a blinking light.
AREA 91
PA SHO SHOP
Area 91
When I had problems pulling codes, I cleaned the "dog house" (OBD1) connector under the hood next to the passenger side strut tower.
jthod
Mr. Goodwrench
Lincoln, Nebraska
:mad::mad::mad::mad::mad:
Saiyancrunks
I tried cleaning it, and nothing. Could it be a bad comp.? like I said, the light does come on, but it only came on once when I drove it. I started it up tuesday and let it run for about 15 minutes, and no light, but it won't read the codes either.
I just want to know what up with this thing!!!! AAHHHHHH!!!
3 year old gas smells bad by the way.:nut:
guse1096
93 Black MTX
MN
Turn key on and see if check engine light comes on right away. That is the bulb check to verify if the bulb is operational. If not replace bulb. If it does light up right away but still wont flash codes I would be looking into a new computer...
jthod
Mr. Goodwrench
Lincoln, Nebraska
come to think of it, I don't think it does come on when the key is turned. I'll pull the air bag light out of the '90 and throw it in there. After 10 years of blinking, that light still works. (no airbag)
jthod
Mr. Goodwrench
Lincoln, Nebraska
The bulb was the culprit, WTF?? Now I really feel like a genius. The bulb does light up though, I put it in the seatbelt spot, and it lights up. It aparently didn't have it's blink function.
I only got 114 and 116, but the battery has been disconnected about 15 times since it last ran, so there's bound to be more when I get it running again.
