Please help !!!!
Jeff93SHOmtx
Red93SHOmtx
michigan
Ive got a 93 SHO mtx and i just put the motor back in it.I bought it without a motor got a motor changed bearing etc all that good stuff.I got it all back in the car and together.My problem is im getting no fuel.I pulled the tank check the plug to the fuel pump and I have no power there.I dont know where the fuse or relays are for the fuel pump.I read something about the multi function relay above the radiator and changed that still nothing.
Jeff93SHOmtx
Red93SHOmtx
michigan
yes the motor hasnt fired yet i shot it with a little gas through the throttle body and it fired for a split second.
Racer X
SHO Pilot, Retired
Connecticut
Have you checked the inertia switch? Left side of trunk, just behind the wheel well.
zblackbeast
SHOtarded
Omaha, NE
Check the fuel pump cut off switch on the drivers side inside the trunk. make sure that button is pushed in. I had that problem when i got my 93's motor back in the car..
Jeff93SHOmtx
Red93SHOmtx
michigan
should i make a ground wire and run it from the back of the intake to the firewall or go get a ground strap
