40BelowSummer
My car has been getting work done slowly by myself over the last two weeks for a few hours each day after work.
I just finished changing the rod bearings and reinstalling my intake manifold and now the car will not start. It turns over; accessories turn.
If, by chance, it was something that went wrong during the rod bearing replacement (hope and doubt this isnt the case) wouldnt it at least start up and knock or seize up? I just want to rule this out so Im not sweating bullets all day.
If I turn the key to crank the car, the tack doesnt go past 150-200 RPMS, which I cant remember if it is normal or not.
Any and all input appreciated, today is my last day off to get this thing running.
Thanks
Rhett
- I seem to be getting spark. I took a spark plug boot off and I could see it arch or spark when I turned the car over.
- I changed the DIS
- Intake seems to be grounded fine.
- No oil leaks, proper oil level
- I ran the codes (KOEO) and I got a 542, which I know usually comes up if the car has been stalled or something. Would I get this code from it cranking and not starting? Because it hasnt had a battery in it for a while, so it coudnt have been stored from before today.
- Ive been doing ALOT of electrical work on the interior, so I check all fuses under hood and inside the car and they all looked fine.
Thanks
Rhett
Although I do have a basic trie pressure gauge, the one where the pressure pushed the white thing out that tells the psi. Maybe it will at least tell if i have pressure and give me a good idea.
