LookAtThatSHO
Who's SHO Daddy
Hello All,
Hopefully someone can provide some insight as to what might be wrong with my 93 MTX. I went to start the car earlier this morning, and without warning, it continuously cranked and cranked, but it would NOT turn over. Note that I did hear the fuel pump turning over. After about 10 minutes, the smell of gas was evident (flooded), and there's at least a half tank of gas remaining. So, I gave up, and went to work with my girlfriend's car. While at work, my father performed the Key On Engine Off test and got the following:
114 (O,R) IAT sensor out of range - IAT
116 (O,R) Engine Coolant (ECT) sensor out of range - ECT
Neither of these appear to be the culprit though.
After sitting for a bit, my father tried starting it again, this time with a test light attached. One end was attached to the end of the spark plug wire, while the other end made contact to the ignition coil pack. It did in fact start, but after he turned the car off, it has not started since.
After connecting a battery charger and letting it sit for a bit longer, we just went out to see if we were getting any spark with the test light. We are now getting NOTHING.
Thus, I am thinking that the problem has to be at the coil pack itself, or somewhere in line before the pack. Perhaps the PCM, or CPS (Cam or Crank)? Apparently, my father mentioned that there might be a condensor near the coil pack. Could that be what's causing this?
Any help/input would be greatly appreciated - I'm really in a bind here!
Thanks Again Everyone!
-Mike
-Mike
