Hello. Thanks for the feedback. This part is 3" (76mm). When I disassembled a 1995 SHO a few years ago, this part came out of the shock absorber/suspension assembly, however, it has no identification (part number) and I also couldn't find it in catalogs by the format where it fits.What is the approximate size of that? If about 3.5 inches / 9 cm (eyeballing, not direct conversion) then it might be one of the front subframe mounts. Did you find it underneath your 1992 SHO, and was it towards the front or the rear of the car if so?
Hello. Exactly this part. My 1992 SHO is without this part and apparently everything works fine. I honestly don't know the purpose of this part, but if it is there it is because someone in engineering predicted this part. Thank you very much for your attention.Rear Strut Component Identification
Hey guys. This is turning into a real shit show. I really should have just bought fully assembled struts. My rear struts have never been replaced by me, which is why I don't have any receipts. The rear suspension is all fused metal and rusty parts. I have already ordered new end-links, and...shoforum.com
You are on the right track. It came from a rear shock absorber. Sits on top of the spring.Hello. Thanks for the feedback. This part is 3" (76mm). When I disassembled a 1995 SHO a few years ago, this part came out of the shock absorber/suspension assembly, however, it has no identification (part number) and I also couldn't find it in catalogs by the format where it fits.
