P1505
Izzmo
SHO Enthusiast
Kansas City, KS
So, I got this error this morning causing the CES to flash: P1505.
Any ideas? I Looks like no one has had this on this forum before or v8sho.com.
stephen newberg
Ladysmith, BC, Canada
If the IAC itself fails you are going to get hard starting and uneven idle. Most often, from what I understand, this happens due to a dirty sensor in the MAF. I have not, however, heard of getting this code as a result, so your problem might be different than the somewhat common one of the sensor.
pax, smn
Izzmo
SHO Enthusiast
Kansas City, KS
I found this:
http://helpforcars.net/obd_codes/p1505_ford.html
But you are right, I have not heard that one before.
pax, smn
Yeah it's an odd one.. it sounds like the IAC is bad.. but it's working fine as far as I can tell (if not, then I would assume the car wouldn't idle since the valve needs to work in order for it to do so unless maybe it's stuck open?)
What happens typically when a IAC fails on a V8?
Devin, usually the engine shuts off due to insufficient air flow.. but that's not happening.
I cleared the codes, so I guess we'll see if it comes back. I got a whole slew of codes with it though, 2 being misfires on cylinders 1 and 3.
decipha
EFI Dyno Tuning
New Orleans, LA
that code simply means the ecu cannot control idle rpm via the IAC valve, it doesn't necessarily mean the ISC valve is bad
you most likely do not have your throttle body set screw set correctly
invoke a base idle reset as outlined in the link below
http://info.efidynotuning.com/idleair101.htm
in the drop down menu scroll down to base idle reset and read the section for a base idle reset on a stock tune
should resolve all your issues, could possibly be a vac leak causing havoc too
