Over heating
SHOstuff
Houston,TX.
Question I have is is there a fuse for the radiator fan or what cause my radiator fan is not coming on and I can't find a fuse if there is one for it. Also on the a/c unit can I use the same one that comes out the continental cause it looks exactly the same. Please answer these questions I would be so relieved. Just tell me what to do with radiator fan problem.
rendyx
Buffalo, NY
You might try replacing your ECT sensor. This is what tells the computer the coolant temperature. The temp-sender is for the gauge only (correct me if I'm wrong). ECT's cost about $15, and are easy to change. It is to firewall side of the thermostat housing.
