Oil Pump Question?
93rev2sev
Hockeytown
none that I've heard of...but you would never know that it failed. If it fails, you spin a bearing...then the pump eats the bearing schrapnel and hides it's own failure.
If you spin a bearing the pump will suffer badly.
Off Road SHO
Moderator
If and only if you are reving it so high that the oil filter goes into bypass. Otherwise, the filter will catch all debris. I have one brand new Ford 3.0 oil pump left if anyone needs a new one.
Tom
93rev2sev
Hockeytown
Tom
Wouldn't that be the likely case? And I'm also guessing that the copper becomes granular, clogs the filter and it bypasses.
Off Road SHO
Moderator
I kind of doubt it. You'd have to spin 2 or 3 bearings to get enough material to clog a filter. But strange things happen. The bypass is not like a lightswitch either open or closed. It's a blow-off like valve that gradually open and closes. Probably starts to bypass some oil at 3500 rpms and is bypassing 60 % of the oil flow at 7000.
Tom
AREA 91
PA SHO SHOP
Area 91
Tom
Damn! I've been looking for a NEW 3.0 oil pump. I got Pay Pal...:p
yamahaSHO
E85 whore
Arkansas
My oil pump was fine after spinning a bearing. There was some material on the gears, however, it comes off with a finger nail. Gary M. and I measured the clearances and it is still a good pump.
93rev2sev
Hockeytown
Tom
Understood. It makes good sence.
Thank you.
93rev2sev
Hockeytown
Then why did you replace it?
J/K...givin you a hard time...new is always better than "good used"
