medgraphsho
Bill T.
Sometimes the light will stay on when I turn the car on, sometimes it will go out after the 5 sec power up?? I checked the oil level, it is above the hatch marks.... would too much oil make the light go on and off???
I did everything you saidIf it's the red light don't drive the car again before you change the rod bearings. If it is the orange 'check oil' light, you need to accurately check the oil and add as required.
When the oil is above the hatched marks, is the car level? Has it sat for awhile after shut down? Did you wipe off the dipstick and then stick it back in to get an accurate reading?
kl;l;kk;Yes The car is level, it has sat overnight, I wiped the dipstick down and stuck it back in..
Doug
