Oil leaking from oil filter bung
LJRuddy
Pop lock n drop
Poaceae fields
Anyone have an oil leak coming from the top of the oil filter before? I'm trying to figure out what exactly is leaking... I've noticed about 4-5 drops of oil fall from the oil filter every night in a piece of cardboard. The trail of oil goes up the side of the oil filter but I can't really see where it goes after that. I loose maybe 3/4 quart of oil every 5,000 miles (my oil change schedule) so its not a huge leak. I'm just tired of having to park on card board every night so I don't stain my roommate's brand new drive way. :nut:
Oil pan is dry so I'm guessing it has something to do with the filter bung....
LJRuddy
Pop lock n drop
Poaceae fields
Oh man this looks like tons of fun to take off... Thanks for the link! Somehow I knew it wasnt going to be something simple :nut:
SHO U UP
SHO Guru
Virginia Beach, VA
^It's a simple job bud. Just empty the coolant before you begin or you will get an antifreeze bath. The only special tool I think you'll need is the 30mm socket (IIRC) to remove the filter nut/housing. Good luck with it.
Izzmo
SHO Enthusiast
Kansas City, KS
Does it ever stop Liberty? I know whenever I change mine or my brothers oil, it will leak a few drops upon initial startup and then stop. (Not sure why it does that).
LJRuddy
Pop lock n drop
Poaceae fields
Its continuous and appears after 3-5 minutes of the engine running after an oil change.
You don't have to take it off the car to fix this. Just remove the filter then with a large socket remove the center stem. This will allow you to replace the O ring. I would not use loctite either as it is very difficult to get a grip on the slim hex and with loctite it will be next to impossible to remove it later.. It will be very tight the way it is.
Dark Light
Langhorne, PA
i have the same problem with mine...when i bought it in 2006 it was just a few drops but now it leaks worse..ill have to change out that o-ring see what happens
