saleenboy87146
I've had my 1994 SHO ATX since Oct. of '97. It's been a great car, just needing routine maintenance. I run mobil 1 and really only chagne oil twice a year. The car has always been virtually leak free( knock on wood ). The last few times I have changed oil I noticed the rear of the oil pan( drivers side ) has been getting a little more damp, never enough to drip though, until now. In the last month or so, all you can smell when driving is oil, and it leaves puddles every where. I crawled under it to investigate a little, the whole top of the tranny is soaked with oil and the rear portion of the oil pan. When I look from the top I can't really see anything. I was gonna pull the passenger side fender well liner and see if I could see more as I can't really where it is coming from, from underneath. Just been way to cold to really work on it ( like less then 20 degrees the last few weeks )
My question what would be leaking higher up on the engine towards the rear of the engine.
Thanks
Scott
Thanks
Scott
