Oil in spark plug wells
Off Road SHO
Moderator
Old spark plug well seals allow the oil to be sucked in as the engine cools down.
These seals along with the valve cover seals come in a FelPro kit that you can get at AutoZone and probably most of the sponsors of this Forum.
When the cover is off you can only adjust the valve lash (slop). You won't need to grind the valves and seats for a long time, and you will need to remove the heads from the engine inorder to do the valve grinding.
Tom
supersport
Pennsylvania
what would be the cause for this, a bad valve gasket? or other problem...i think when the cover is off i might redo the valves..where can i get both these parts?
SHOBlu
Habitual Offndr
New Sharon, Maine
Is this one of the new "backward" threads I've heard so much about :nut: or are you just spouting out information Tom? LOL
93rev2sev
Hockeytown
What is a common cause for misfires on V6 SHOs, Alex...
Oh... its not Jeopardy?
shogansta
Change Username
Istanbul Turkey.
Im sooo confused im going to run into a wall and bang my head there for the next 12hours to figure out what happend
LJRuddy
Pop lock n drop
Poaceae fields
zzzzzzzZZZZZZzzZZzzZZZZZ......
:oogle: ANSWER IS GEORGE WASHINGTON!
oh... sorry, i was asleep...
One of the reasons is the excessive blowby of the V6 SHO. The PCV system is quite under performing. This results in carbon build up behind the rings allowing the pressure to build up in the crankcase.
Auto-RX to the rescue....:hdance: :hdance:
