Off Road SHO
Moderator
Old spark plug well seals allow the oil to be sucked in as the engine cools down.
These seals along with the valve cover seals come in a FelPro kit that you can get at AutoZone and probably most of the sponsors of this Forum.
When the cover is off you can only adjust the valve lash (slop). You won't need to grind the valves and seats for a long time, and you will need to remove the heads from the engine inorder to do the valve grinding.
Tom
Tom
or are you just spouting out information Tom? LOL
ANSWER IS GEORGE WASHINGTON!
