Oil cooler. Coolant hose
patrick hubbard
Pratt, ks
My oil cooler Coolant hose from the block to the cooler burst. Does anyone know where I can get a new one
GEN 3 SHO FAN
Canada
Mostly made in unobtainium now...
I replaced the exact same hose this spring with a generic one. It was a Pita because mine doesn't have curve in it and there is not much space there.
After some time watching this, I came to wandering if we can interchange the hose placement, the short hose exiting the engine plugged on the other plug and the longer one going on the plug nearer of the engine (the one going to waterpump).
The only change is the coolant flow in the cooler is reversed. Hose replacement could be very simplier then. Maybe a veteran can confirm this.
gamefanatic
Barstow, CA
My experience earlier this year, left me walking to the nearest Autozone to get one and performing the surgery in a gas station. I used a standard hose as the OEM styles are not available. Cut to the right length you shouldn't have to worry about kinks in the hoses.
Oil cooler to engine block is : 9/16" ID. Pretty sure its the same for the oil cooler to the coolant pump.
99sho-time
I caught mine in time mine was gummy and swollen badly in one area. i just a straight hose piece have a slight kink in it but a small kink is better than a potential burst.
outatyme357
I sized the oil cooler line barbs at 14.02 and 14.10 mm respectively and just ordered up a gates 20605 for the block to cooler hose - will update when this arrives to see if this will work out for others as a solution - similar to what i had to do with the idler pulleys....
outatyme357
the oil cooler o-ring bore is 69.37mm OD and 61.15mm ID and 2.4mm deep respectively btw.
For the valve covers,
F6DZ-6F048-BA (Small gskt, SHO, Require Quantity: 2) OBSOLETE
has the following dimensions:
23.7651 OD
16.2761 ID
9mm deep
(1.75mm high x 1mm wide lip at top)
and
F6DZ-6F048-AA (Gasket Large gskt, SHO, Require Quantity: 8)
35mm ID
42mm OD
9mm deep (high)
